WiFi Pod management
charlieannear
Is it possible to see what is connected to a WiFi Pod?
Even better, is it possible to choose what is connected to a WiFi Pod?
I can see the WiFi Pod in the Connect app, and I can see 1 item is connected to it, but I can't see what it is.
Ideally I'd like to be able to ensure my Ring Chime Pro is connected to it, because that's what I needed the Pod for!
2 REPLIES 2
Legend
The Ring Chime is free to switch between the Wi-Fi signal from the VM Hub and the VM Pods, the reason is they all have the same SSID / Password..
Using a retail Wireless Repeater, it possible to set the relayed signal to have a different SSID to the VM Hub and then Ring Chime Pro can be connected to the preferred Wi-Fi service which can be from the Wireless Repeater.
Kain_W
Hi charlieannear,
Thanks for your post and welcome back to the community.
Just regarding the Pod, it's more of a Wi-Fi extender as opposed to the boosters we used to have.
Do you have any ethernet connection plugged into the Pod?
Let us know,
Kain
