WiFi Pod led's
Donfor40
Superfast
Quite recently my only Wifi Pod has stopped randomly
Lighting up bedroom.
The LED still flashes on top of Pod, yet No Illumination effect as before.
1 ACCEPTED SOLUTION
Accepted Solutions
Hi Donfor40.
We have attempted to send you a private message, but you do have your private message facility turned off. Could you please turn it on so that we can send you the private message required to assist you.
Thanks.
Sabrina
12 REPLIES 12
Martin_N
Hi Donfor40,
Thank you for your post. I'm very sorry to hear about the issue with your WiFi pod.
Can you confirm if the pod shows on the connect app?
^Martin
Donfor40
Superfast
Yes Pod is seen via Connect App albeit with Triangle Esclamation Symbol.
Thank you for that. Have you fully disconnected the pod from the hub and reconnected it?
^Martin
Pod Disconnected as required, cannot locate it via Connect App.
Thanks for coming back to us Donfor40, are you able to remove and re-install the Connect App to see if the pod will show up on there?
What is the current status of your pod, are there any lights flashing or pulsing at the moment on your pod?
Kind Regards,
Steven_L
Donfor40
Superfast
Whilst there are Random Low or Dim lights on Wifi Pod, by no means Lighting room as before.
Is it possible that my Pod has been remotley 'Switched Of'f as I droppped from 1gb/500gb now 54gb with Stream package.
I'll try re installing App though not sure how it can help.
thanks
Hi @Donfor40.
Thanks for reaching out to us regarding your WiFi pod issues. In order to assist you further, we would need to bring you in for a private message to discuss this and resolve. Please look out for the envelope on the top right of your web browser or if you are using a mobile device it will be located under your profile icon.
Thanks.
Sabrina
Hi Donfor40.
Thanks.
Sabrina
Donfor40
Superfast
If Private message could be sent please as Ide like to find Pod solution.
thanks
