on 04-01-2022 18:18
I have taken delivery of my new WiFi pod in the hope of reducing blackspots in the house and as part of my deal with Virgin.
However the light keeps flashing - probably for over an hour now.
I've moved it closer to and further way from the router without success.
Is my only option to sit for an hour on their helpline to get a replacement??
on 27-07-2022 10:21
Is anybody available too fix this issue?
I was told this would an escalation was made on friday evening but they are still constantly flashing white?
Kind regards
Dean 😢
on 12-08-2022 08:11
Hi, I have this issue too, on all 3 plugs. Have rebooted router, no joy. Have taken all 3 out, put first one back in and hours later still flashing white.
on 14-08-2022 16:10
Good Afternoon @Weefifer, thanks for your post on our Community Forums, and I'm sorry to hear of the issues with the Wi-Fi pods.
Can you please confirm if you've been able to reset the router and the pods since your post?
Kindest regards,
David_Bn
on 14-08-2022 16:26
Hi David, the answer is no. They are all currently unplugged. If I connect smart WiFi, pods connect but it’s automatically picking 108 which is a dfs channel and my tv, sound bar and speakers can’t use that band, so no surround sound. Someone was phoning back from virgin???? But not heard from anyone.
so at the moment, I have it on 2.4 and 5g, auto selection but smart WiFi disabled and everything works fine
it was all working ok till about 3-5 days ago with smart WiFi on so don’t know what’s happened. Router has been reset numerous times with no joy.
on 16-08-2022 17:31
Hi Weefifer,
Thank you for your reply, I have checked our systems and can see you are affected by an SNR (sound to noise ratio) Outage, this can affect your pods as can affect your speed and range so this will explain why your pods are flashing.
Zoie
on 16-08-2022 17:54
Thanks zoie, so how do I fix it?
Ive left them unplugged, as each time they are switched on using smart WiFi, it’s selecting channel 108 and a few of my things can’t work on the dfs channels.
on 18-08-2022 20:44
Hi @Weefifer,
Thanks for your reply. Unfortunately, there isn't a way to resolve an SNR Outage, as this is something our Technicians need to fix and resolve physically. I've taken a look at things on our side, and can see that the outage is still ongoing and is due to be resolved by 22nd August by 9AM.
I can also see you've spoken with our team since your post. Have they been able to assist with this?
Cheers,
on 18-08-2022 20:48
Thanks for the info. Well, still waiting on a call, been at least 4 days since they said they would call but nothing so far, really poor service. The pods are sitting in a box. Also it’s a long time to sort out the outage.
on 21-08-2022 09:51
I can appreciate the frustration caused during this Weefifer,
Just to clarify, have you received a call since posting?
Let us know,
on 21-08-2022 09:58
Thank you, but no phone call at all. Pods still unplugged and sitting in a box
