shywitch
  • 46
WiFi Network & Printer (offline)
I am in big trouble (for me). Did the 192.168.0.1 bit and it asked for the password for Hub 3. Password that is on the sticker doesn't work. So I can't access to change my network password. 4 wires on the back of the router... Also on one of the wires is ..ONLY TO BE USED WITH SUPER HUB 2 VMDG485.
I have logged my phone onto the wiFi and that password on the sticker works. How can I access the page to change my network name from VM5034247 and also to change my password.
HELP!!! Please. Also it says "weak security" which I didn't have before. Have a feeling a neighbour might have accessed my wifi.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: WiFi Network & Printer (offline)
"Also on one of the wires is ..ONLY TO BE USED WITH SUPER HUB 2 VMDG485."
Where did that information come from ?
The password you need to get into the Hub Settings is the one highlighted below.
Hub-3-Password
If that doesn't work you will need to do a Hub reset using the exact method shown below ...
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once the lights are stabilised check your system again.
shywitch
  • 46
Many thanks for your help... found the other password & got it sorted. 🙂
