WiFi Intermittent Drop
Hello,
The last month or so, our internet WiFi signal has dropped and stopped broadcasting repeatedly.
Within a few seconds to minutes, it returns.
Any advice would be much appreciated.
Before I have had Pre RS in the four figure, and Post RS in the 5 figure range and 4 to 4 T3 time-outs but currently the router logs look like this;
 bonded channels
1 443000000 7.3 40 256 qam 37
2 251000000 7.9 40 256 qam 15
3 259000000 8 40 256 qam 16
4 267000000 8 40 256 qam 17
5 275000000 7.8 40 256 qam 18
6 283000000 7.5 40 256 qam 19
7 291000000 7.6 40 256 qam 20
8 299000000 7.5 40 256 qam 21
9 307000000 7.5 40 256 qam 22
10 315000000 7.5 40 256 qam 23
11 323000000 7.5 40 256 qam 24
12 347000000 7.5 40 256 qam 25
13 355000000 7.3 40 256 qam 26
14 363000000 7.1 40 256 qam 27
15 371000000 7.4 40 256 qam 28
16 379000000 7 40 256 qam 29
17 387000000 7 40 256 qam 30
18 395000000 7.1 40 256 qam 31
19 403000000 7.5 40 256 qam 32
20 411000000 7.8 40 256 qam 33
21 419000000 7.6 40 256 qam 34
22 427000000 7.5 40 256 qam 35
23 435000000 7.6 40 256 qam 36
24 451000000 7.4 40 256 qam 38
1 Locked 40.9 6 0
2 Locked 40.9 4 0
3 Locked 40.9 4 0
4 Locked 40.9 8 0
5 Locked 40.9 5 0
6 Locked 40.9 5 0
7 Locked 40.9 6 0
8 Locked 40.9 5 0
9 Locked 40.3 5 0
10 Locked 40.3 5 0
11 Locked 40.3 4 0
12 Locked 40.3 7 0
13 Locked 40.9 4 0
14 Locked 40.3 5 0
15 Locked 40.3 5 0
16 Locked 40.9 5 0
17 Locked 40.9 4 0
18 Locked 40.9 5 0
19 Locked 40.9 5 0
20 Locked 40.9 5 0
21 Locked 40.9 4 0
22 Locked 40.3 0 0
23 Locked 40.9 5 0
24 Locked 40.9 1 0
1 60300014 41.5 5120 64 qam 1
2 39400036 41.5 5120 64 qam 4
3 46200026 41.5 5120 64 qam 3
4 53700034 41.5 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
12/11/2020 14:55:30 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 23:29:12 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 23:29:12 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 15:36:15 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 06:07:17 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 06:07:16 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 06:07:16 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 06:07:15 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 06:07:10 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 06:07:9 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 06:07:9 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 03:59:27 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 12:12:36 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 08:57:16 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 01:02:19 notice SW download Successful - Via NMS
09/11/2020 01:00:23 notice SW Download INIT - Via NMS
08/11/2020 12:20:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 21:53:44 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 21:53:44 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 09:52:50 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
RPE83.
  • 24.57K
  • 1.41K
  • 3.12K
Re: WiFi Intermittent Drop
When was the hub last rebooted?
Hello Gary,
About 1200-1300 today. I had two outages around 1430, 1500 after that.
RPE83
  • 2.77K
  • 114
  • 155
Hi Rpe83,
I will send you a private message so that this can be looked into further - Chris
