28-07-2021 21:52 - edited 28-07-2021 21:57
I recently got virgin media at my property and I've been getting constant high latency and packet loss, and my WiFi/Ethernet seems to disconnecting randomly for a few seconds, which happens on all the devices but not at the same time. I tried using the Ethernet cable which still has the same issue.
When the disconnect happens, the windows network icon shows the little globe, so it's not completely disconnecting and it says something about DNS not being configured properly.
I have reset the router multiple times with the pin-hole reset, I also disabled channel optimization under Smart WiFi, tried splitting the WiFi into 5GHz and 2.4GHz under Advanced Settings->Wireless Security however the issue still persists.
I have attached the network status logs below and my BQM is here
https://www.thinkbroadband.com/broadband/monitoring/quality/share/85fd73fd3303b3e36855e0950e8e8b8fa668ddbe
It mostly happens when I'm gaming and you can see the packet loss spike on the graph when I was playing Warzone. I only 2-3 matches to make sure it's not the server and it still persisting.
on 03-03-2022 21:38
haven't had a revisit since the last one, the last engineer said they won't need to do one, just needed to check something in the cabinets (not 100% sure).
I only notice the issue while gaming, and sometimes during my work calls using zoom where it would hang/freeze for like half a second which I'm not bothered about, don't really notice it while watching videos or browsing normally.
on 06-03-2022 08:49
Hi @6XWJo388n6,
Thank you for the update. Are you noticing any other pattern to the lags and freezing? For example, is it only happening at certain times during the day, or when you're using a specific device?
on 25-03-2022 15:10
on 28-03-2022 14:38
Hello @6XWJo388n6,
Thank you for the update, can you please tell me if you have noticed any improvements since Friday?
Many thanks,
