28-07-2021 21:52 - edited 28-07-2021 21:57
I recently got virgin media at my property and I've been getting constant high latency and packet loss, and my WiFi/Ethernet seems to disconnecting randomly for a few seconds, which happens on all the devices but not at the same time. I tried using the Ethernet cable which still has the same issue.
When the disconnect happens, the windows network icon shows the little globe, so it's not completely disconnecting and it says something about DNS not being configured properly.
I have reset the router multiple times with the pin-hole reset, I also disabled channel optimization under Smart WiFi, tried splitting the WiFi into 5GHz and 2.4GHz under Advanced Settings->Wireless Security however the issue still persists.
I have attached the network status logs below and my BQM is here
https://www.thinkbroadband.com/broadband/monitoring/quality/share/85fd73fd3303b3e36855e0950e8e8b8fa668ddbe
It mostly happens when I'm gaming and you can see the packet loss spike on the graph when I was playing Warzone. I only 2-3 matches to make sure it's not the server and it still persisting.
on 20-08-2021 23:34
Still the same, the ping isn't always high. it happens randomly but I managed to run a speed-test when I was experiencing high latency tonight. attached the screenshot below
on 23-08-2021 08:33
Hi 6XWJo388n6,
Thanks for coming back to us. Sorry to see that you're still experiencing the odd issues every so often, upon checking the account this morning and doing remote test from our end, we cannot locate any issues that could be causing this?
We have performed a speed test remotely from our end which is fine, there are no power level issues or area faults that are affecting you either.
As its been a short while since you last posted, how have things been over the weekend?
Kind regards Jodi.
19-12-2021 13:14 - edited 19-12-2021 13:16
Is it possible for you to run a test again? I seem to be disconnecting more frequently now for some reason.
on 21-12-2021 13:27
HI 6XWJo388n6
It's all looking good here
Can you reboot the hu please then set up a Fresh BQM please
Wait 24 hours and post the results on here
Gareth_L
on 07-01-2022 10:44
sorry it took a while, just got around to doing it yesterday.
on 09-01-2022 10:52
Hi @6XWJo388n6,
Thanks for doing that and apologies for the delayed response here.
I've just taken a look at the BQM you provided and though it seems like there may have been some issues yesterday I can't see anything notable with the connection today. Is this issue currently ongoing for you?
on 11-01-2022 22:43
on 14-01-2022 08:58
Hi @6XWJo388n6,
Sorry to hear this issue is still ongoing for you. Having looked on our systems again today, your speeds are looking good averaging at 110 download, and 10 upload over the last week. There are 2 disconnections showing, but neither are from the date you experienced them, one is from Sunday 9th and one from Saturday 8th.
There are also no downstream or upstream signal level issues showing that should be causing you problems.
The devices that are having disconnection issues, are they all connected via wifi?
All the best.
on 15-01-2022 23:18
on 18-01-2022 10:55
Hi 6XWJo388n6,
Thanks for your responses and welcome back to the community page!
From checking your account I can't find any details that would directly impact your service.
Your hub uptime is 10+ days, would you be able to perform a reboot and allow to stand for 1 minute?
Let us know what the figures are like after.
