  • 13
Message 11 of 19
Re: WiFi Drop Poor Signal strength & multiple dropouts
Hi Emily, yes it happens both to WiFi and wired connection, in fact it's literally off as I type (on my phone) my neighbours were having a lot of issues a few weeks ago and it until they had 3 vans working on their issue we had very little trouble, now it seems were getting it several times a day and that's not great when my wife and I are both attempting to work from home.....
  • 3.77K
  • 154
  • 219
Message 12 of 19
Thank you for the information, does the Hub lights change when these drop outs occur?
Let us know, Emily.
  • 13
Message 13 of 19
Hi Emily, sometimes yes the white light stats to flash but after that dropout, it came back on for a couple of minutes and has dropped again, this time there's no change to the router lights.....
  • 3.77K
  • 154
  • 219
Message 14 of 19
Thank you for confirming that, have you already run through a pin hole reset of the Hub as well? This would be holding a pin into the pin sized hole on the back for a few seconds until the lights change, this will then fully refresh the connection.
Let us know, Emily.
  • 13
Message 15 of 19
I have although it was a couple of weeks ago, I'll try it again now
  • 1.88K
  • 95
  • 176
Message 16 of 19
Hi M111kde, thanks for getting back to us.
Please can you tell us if the pin hole reset did the trick?
Lee_R
  • 13
Message 17 of 19
Hi Lee, no not really we're still experiencing really weak WiFi signal (only really any good in the room with the router) and drop outs.
  • 1.92K
  • 129
  • 178
Message 18 of 19
Hi M111kde,
Hope you are well and enjoyed your weekend.
I can see that you were able to get in touch with our helpline and arrange for a new hub to be sent out to you.
It'd be great to hear back from you once you have received it to see if that solves the WiFi issues.
If there's anything else we can do for you in the meantime just give us a shout.
All the best,
Beth
  • 13
Message 19 of 19
Thanks Beth, I'll post an update once installed and tested for a few days.
Many thanks
