First thing to establish...
____________________
Are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
Is yours a "booster" or a new Pod?
VM Wifi is now “guaranteed” to 20 Mbps/room it’s now called… Wifi Max see.-
