WiFi Boster problem
I have an existing virgin boaster that is not working. I have tried reconnecting it using the virgin app and it says to get hold of technical support. Thanks.
  • 24.94K
  • 1.44K
  • 3.17K
Re: WiFi Boster problem
Set it up manually using the paper instructions not the app.
I have tried that twice before the app and the main light on the main boaster just flashes and it doesn’t work so that is why I the tried the app twice.
  • 24.94K
  • 1.44K
  • 3.17K
Have you factory reset them?
Thank you I have but I am going to try again. Thanks.
  • 1.89K
  • 95
  • 176
Hi SamT1 Thanks for posting and welcome to our community.
Sorry to hear you're having issues with your booster.  Can I ask if taking it back to factory settings has resolved the issue?
Lee_R
