  • 21
Message 1 of 22
WiFi Booster Kit
Here we go.
After doing the checks I needed a WiFi Booster.
So I contacted Virgin and they sent me a Booster Kit out.
I followed the set up to the letter.
Paired etc.
1.4 Make it easier Booster WiFi network same as your Hub.
Again followed to the letter of the instructions.
Plug in switch on.
Loose all WiFi in the house.
Switch off booster get limited WiFi back.
Reset Boosters as per Troubleshooting.
Set up as its own network ID. Switch on.
Loose all WiFi.
Switch off get limited WiFi back.
Try again.
Try to login to the Boosters using the details in the instructions.
Can't find.
Try logging in to my Router, not authorised.
Reset Router.
Get router working again and once more limited WiFi.
Set up Booster switch on...
You know the rest as above.
Any ideas as I can't get through to anyone at VirginMedia Tech help as it it not a Corona Virus neccessity.
  • 20.96K
  • 1.13K
  • 2.7K
Message 2 of 22
Re: WiFi Booster Kit
Invest in your own better boosters or mesh system
  • 11
Message 3 of 22
I invested in BT Mesh discs, without them my internet is so poor its unusable. Customer support, you may as well not bother.....that's if you can actually get through. I called them today, it said "Sorry we are not available to take the call, call back later, goodbye!!" how good is that!
  • 21
Message 4 of 22
I got through to them but when they transferred me to Tech Support I was then informed it wasn't urgent enough.
Even though I have 3 key workers living in my household.
  • 6.06K
  • 308
  • 536
Message 5 of 22
Hi Safron6
Thanks for posting and I am sorry to hear you're having issues with your boosters.
Have you managed to sort this out since posting?
Kind regards,
John_GS
  • 21
Message 6 of 22
 Problem is still on going.
But for now I have given up.
I have tried everything to possibly get it to work.
I will wait to get it exchanged by VM
  • 6.06K
  • 308
  • 536
Message 7 of 22
Can you try this here for me
Kind regards,
John_GS
  • 21
Message 8 of 22
Already followed all instructions from book and online still same problem.
I will await sorting out a swop
Many thanks
  • 20.96K
  • 1.13K
  • 2.7K
Message 9 of 22
Factory reset the boosters then follow the paper instructions that came with them to pair them again.
Do not use the Connect App.
  • 21
Message 10 of 22
Just noticed I forgot to state these are Powerline booster kit.
Plugged into the mains.
