Hey, thanks for the info. I was intrigue by this upgrade in wifi standard as I use the Shadow cloud gaming service currently on Ethernet (over powerline) as wifi 5 as it stands can't cope with the sheer volume of data that gets transmitted per hour. Even with the reduced performance of using Ethernet over power its better than the current wifi capabilities of my hub which is less than 10ft away. I'd obviously rather have a direct connection with ethernet but I'm restricted to what I can alter in my apartment
I'm also acutely aware that the virgin hub is notorious for poor down speeds over wifi anyway, so was surprised to see the spec for the gig hub 4 being the same. It's perplexing as to why Virgin would provide the fastest down speeds only yo be unachievable over wifi on the hardware they provide. I get better download speed on 4g on my phone then i do on my 200mb cable service over wifi.
