DTees
Message 1 of 8
Wi-fi dropping out and 2.4ghz light not on. SuperHub 2.
My SuperHub 2 seems to drop WiFi connection at times and the 2.4ghz light has stopped working. It is very difficult to get to talk to the Virgin team about getting a replacement. I have spoken to someone twice in the last year and was told I could have a replacement but that hasn't happened. I just keep going round the same loop. The internet connection says it is fine but I think it is also affecting our Hive heating. I have disconnected our 2 Alexa devices and our Hive hub to set them back up and I have reset the SuperHub 2 plenty of times like the website keeps suggesting.
How do I get a replacement especially as I don't think our service deserves the extra monthly increase!!!
Don't keep offering improvements only to increase the price soon after!!
Tags (1)
gary_dexter
  • 28.92K
  • 1.77K
  • 3.78K
Message 2 of 8
Re: Wi-fi dropping out and 2.4ghz light not on. SuperHub 2.
The hive hub connects via Ethernet not Wifi so shouldn’t be affected by the Wifi dropping out.
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 3 of 8
You need to try the lines when they open at 8am.
Some say that the older HUBs are actually better than the newer HUB 3 and HUB 4, it's just unfortunate that they eventually break!
If you are willing to outlay a budget you could keep your existing HUB, put it into modem mode, and use your own router.
DTees
Message 4 of 8
Hi Gary yes I do know that but I think the hub is failing as both seem to be having a problem.
Chris_W1
  • 3.6K
  • 160
  • 207
Message 5 of 8
HI DTees, thanks for the message and sorry to hear that you are having issues with the service and we want to get things resolved. I will send you a private message so that we can look into things further for you. Chris
Chris_W1
  • 3.6K
  • 160
  • 207
Message 6 of 8
Hi DTees, thanks for the message and we are happy to see that this is on the way to getting resolved. Please let us know how it goes. Chris
DTees
Message 7 of 8
Thank you. That's great. I'll let you know how things go.
Chris_W1
  • 3.6K
  • 160
  • 207
Message 8 of 8
No worries, have a good day. Chris.
