Wi-Fi pod not connecting to new hub 5 router
Cholski92
Hi I got a new Hub 5 router and previously I used a WiFi pod via eithernet cable to connect my PC. After installing the new router when it come today, My pod isn’t connecting and it’s constantly flashing. I’ve unplugged and plugged it back in after a short while.
Any help would be much appreciate 😊
3 REPLIES 3
Legend
Call the activation number 0800 953 9500, request the VM Pods are paired to the replacement Hub.  For the call have to hand the full details from the Hub’s sticker and ALL the VM Pods.
And see if anything in message 5 in this thread helps to connect Pods…
https://community.virginmedia.com/t5/Networking-and-WiFi/WiFi-boosters-needed/m-p/5122436#M497217
Kath_F
Hi Cholski92,
We're sorry to hear you've had some issues with your pods connecting to your new hub. We will need to re-provision the pods to work with your new hub. In order to do that I will need to confirm some information with you to pass security so I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
Kath_F
