Oakley22
Wi-Fi pod - made no difference
Hi I have a Wi-Fi pod plugged into my daughters bedroom and it hasn’t made any difference, do I need more then one?
  • 1.74K
  • 109
  • 399
Super solver
Re: Wi-Fi pod
If your daughters room is where you wish to have better coverage the pod should be located about half way from her room to the Hub.
Oakley22
Re: Wi-Fi pod
Her room is basically a dead zone for internet so I put it in her room but I’ll try that, thanks.
  • 1.74K
  • 109
  • 399
Super solver
Re: Wi-Fi pod
The pod is a radio relay.  It need to be in a position where is gets a decent signal to re-broadcast further into the home.
If the pod in a dead zone it also can't hear the Hub's WiFi so can't work as intended and often makes matters even worse.
Oakley22
Re: Wi-Fi pod
Any suggestions as to what I can do?
  • 13.83K
  • 1.07K
  • 2.8K
Re: Wi-Fi pod
Pods should always be placed as near as possible mid way between the VM hub and the target machine. If they are in the same location as the target they will just be getting the same strength WiFi signal as the target machine and retransmit a low level signal.
