30-11-2022 23:15 - edited 30-11-2022 23:28
Hello.
I've got a weird problem, involving the Superhub 3. I'm on the M350 package.
Sometimes some of my devices just stop working when on the Wifi. They will be connected but just won't do anything.
For example, my laptop will say connected and have full bars but then just won't load a page and will error. I've also had this happen with my iPhone 12 Pro, where it's connected but nothing works.
Furthermore, my Ps5 will randomly drop connection while playing and log me out, and it picks up the SSID, but when I do a test on the ps5. Sometimes it fails when trying to pick up the ip address, and others it failed when trying to connect.
I also received an iPad 9 from eBay today, and that's also been doing it, but then on the other hand half the other wifi devices in the house are working fine.
im not sure what to make of this and have a feeling it could be a router issue as this issue only started a few weeks ago and was working before.
on 01-12-2022 14:28
on 01-12-2022 23:08
Hello,
I believe Ethernet is fine, the only device on Ethernet is the cctv but haven't seen it go down.
It seems to be wifi devices that are faulty and not all at the same time and it never was like this before, everything had worked fine. I've had it happen in the room next to the hub but not as much as it happens downstairs, but the wifi router has been in the same spot for years and never had a problem.
I will try turn off the channel optimisation first alone and see what happens but would prefer to keep it as a joint SSID & not separate due to the seamless experience it brings but will try it as a last resort.
thank you
on 02-12-2022 15:18
on 03-12-2022 03:23
Hello,
Unfortunately I'm on a Volt350 bundle but I saw these pods before and then decided against it because my wifi was fine up until recently but I'm struggling to understand why it acts this way as monitoring a BQM on the network is fine.
Genuinely I don't feel like spending money when I've had the SH3 in the same spot for years and it's never been a problem. I did look at replacing the router with a good Wifi AX router with MIMO etc. But thought the SH3 has surprisingly been trouble free 95% of the time.
I'm going to wait and hope a VM rep can reply and look into it.
on 03-12-2022 03:43
@ASingh1 wrote:Hello,
You are on a Volt package so the pods are free. Try them, you have nothing to lose.
You can only order one at a time and need a weeks gap before ordering a second one.
04-12-2022 22:16 - edited 04-12-2022 22:25
Hello,
I found them on my virgin media login but after I go to checkout, it says "From month 12 of your original plan, your total monthly cost will be £76.95. Prices may change. The remainder of your original 18 month minimum term applies."..
Can you explain this? It is currently £34 and it was an 18 month contract which expires October 2023. Does it mean the price changes to £77 from month 12 instead of remaining £34? If so, I am not going to take the pods.
What I am struggling to understand is that it works on some devices in the same location but not others. Or they will work and off.
If you look at the link below, I have attached some examples of what is going on.
So e.g. - the PS5 will connect fine sometimes, no issues at all but other times it will not connect to the wifi etc. and struggles for like 15 minutes, but the signal strength is always 80+%.
As I am typing this, my wifi on my laptop is cutting out at times and not working but it has been connected throughout, as witnessed with one of the imgur images where pinging a site can time out. But my phone is working fine right now.
But other times my phone will cut out too.
Just seems to be timing out a lot.
I also ran a test on the VM Connect App in the room and you can see the hub latency ended at over 10000ms, but the speeds are high.
The imgur link is:
https://imgur.com/a/Qqaga4h
I am hoping a VM rep can check my connection soon.
on 07-12-2022 09:18
Hi ASingh1,
Thanks for your post and it's great having you back in the Community.
I'm sorry to hear that you are having continued issues with your WiFi connection. Checking our systems, I can see all is looking well with the Hub in terms of power and signal levels, uptime and time outs. There are no faults open that may be affecting you either.
There are so many things that can influence a WiFi connection some of which include but are not limited to, a fish tank being in the same room, walls being built with concrete instead of brick, it could even be that your next door neighbours router is interfering with yours. Due to this, we are only able to offer limited help. Please have a look here: WiFi Help.
The Hub's location could also be causing the coverage problem so we do need to check the positioning of it. Even if it's in the same place as previous, it may now need adjusting. Can you please ensure the following:
Think of the Hub as a radio, and WiFi as the sound - the further away you are from the radio, or the more obstacles that are in the way (walls, electronic devices etc.), the quieter the radio & the poorer the WiFi.
The results from the home scan you've done via the Connect App look good too. If a pod could help, it would have suggested it.
Finally, where you've posted about the contract changes, it looks as though you are changing your bundle as opposed to just added our new WiFi Max service here. If you would like to add this, we can do this for you.
Please try the WiFi tips above first and keep us posted on how you get on.
07-12-2022 21:40 - edited 07-12-2022 21:44
Hello,
the wifi box has been in the same place for years.
Never had any problems before so I'm not sure what's going on.
everything is in the same place and never had a problem. It was working up until like 3 years ago but the latency on the virgin media connect app for the hub is high.
on 11-12-2022 11:29
Hi @ASingh1,
Did you manage to look at the WiFi help link Kath sent?
If you would like to add the new WiFi Max to your account, let us know.
