Wi-Fi extenders and networking in house
mamir5
Hello
I’m new to Virgin Broadband having recently moved into a new house supplied by Virgin.
I have the 1 gig package which works well in the rooms near the router.
How can I obtain some virgin Wi-Fi extenders for the furthest away rooms?
Also, most rooms have a flat type ethernet port which I’ve not seen before. Am I able to connect the router into one of the sockets and have ethernet like connectivity upstairs?
Thank you, and apologies for being so clueless
1 REPLY 1
Photos would help. Also if they are Ethernet sockets, the cables should all terminate in a central location to a switch. You need to ask the builder where this is. Usually in a cupboard or under the stairs etc.
