on 27-02-2022 05:54
Hi I am noticing a lot of internet connection dropouts which I had a lot of yesterdays whilst doing a radio show .... it kept disconnecting, I have run a report and the findings are below, can any help, please.
This has been happening for over a week now
27/02/2022 05:33:17 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/02/2022 05:33:9 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/02/2022 05:31:59 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/02/2022 03:20:30 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/02/2022 02:57:34 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 21:31:38 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 21:31:37 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 14:13:56 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 14:13:56 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 13:44:1 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 13:44:1 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 13:42:59 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 13:25:54 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 13:25:49 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 13:20:33 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 13:14:24 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 13:04:32 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 12:59:59 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 12:59:59 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/02/2022 12:59:13 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 27-02-2022 08:30
Post the rest of the hub statistics
on 01-03-2022 10:50
Good morning @Pizey,
Welcome to the forums & thank you for taking the time to post.
I am sorry to hear that you have had some issues with your services.
As requested, would you be able to provide us with the rest of the network logs?
Kind regards,
Zak_M
on 01-03-2022 20:45
1/03/2022 20:35:52noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/03/2022 20:35:15Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/03/2022 08:31:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;28/02/2022 11:07:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;28/02/2022 08:14:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 21:13:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 20:45:8noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 20:44:53Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 19:27:12criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:45:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:45:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:16:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:16:29criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:16:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:15:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:15:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:14:6criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:12:42Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:12:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/02/2022 14:10:40Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 01-03-2022 20:53
this is all the info i could get unless some one could let me know what i am missing
on 01-03-2022 21:03
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt057-b.cm |
SFID | 155738 |
Max Traffic Rate | 117000047 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 155737 |
Max Traffic Rate | 10500047 |
Max Traffic Burst | 16320 |
Max Concatenated Burst | 16320 |
Scheduling Type | BestEffort |
on 01-03-2022 21:04
Cable Modem StatusItemStatusCommentsAcquired Downstream Channel (Hz)
Ranged Upstream Channel (Hz)
Provisioning State
on 01-03-2022 21:05
1 | 203000000 | 4 | 40 | 256 qam | 9 |
2 | 211000000 | 3.7 | 38 | 256 qam | 10 |
3 | 219000000 | 3.7 | 40 | 256 qam | 11 |
4 | 227000000 | 3.9 | 38 | 256 qam | 12 |
5 | 235000000 | 4 | 40 | 256 qam | 13 |
6 | 243000000 | 4.3 | 40 | 256 qam | 14 |
7 | 251000000 | 4.6 | 40 | 256 qam | 15 |
8 | 259000000 | 4.9 | 40 | 256 qam | 16 |
9 | 267000000 | 5 | 40 | 256 qam | 17 |
10 | 275000000 | 5.1 | 40 | 256 qam | 18 |
11 | 283000000 | 5.5 | 40 | 256 qam | 19 |
12 | 291000000 | 5.6 | 40 | 256 qam | 20 |
13 | 299000000 | 6 | 40 | 256 qam | 21 |
14 | 307000000 | 6 | 40 | 256 qam | 22 |
15 | 315000000 | 5.9 | 40 | 256 qam | 23 |
16 | 323000000 | 6 | 40 | 256 qam | 24 |
17 | 331000000 | 5.9 | 40 | 256 qam | 25 |
18 | 339000000 | 5.8 | 40 | 256 qam | 26 |
19 | 347000000 | 5.6 | 40 | 256 qam | 27 |
20 | 355000000 | 5.4 | 40 | 256 qam | 28 |
21 | 363000000 | 5.5 | 40 | 256 qam | 29 |
22 | 371000000 | 5.5 | 40 | 256 qam | 30 |
23 | 379000000 | 5.6 | 40 | 256 qam | 31 |
24 | 387000000 | 5.8 | 40 | 256 qam | 32 |
1 | Locked | 40.3 | 17504 | 177 |
2 | Locked | 38.9 | 16410 | 232 |
3 | Locked | 40.3 | 15045 | 174 |
4 | Locked | 38.9 | 21072 | 45 |
5 | Locked | 40.3 | 17875 | 55 |
6 | Locked | 40.9 | 12546 | 54 |
7 | Locked | 40.3 | 12257 | 49 |
8 | Locked | 40.3 | 12315 | 71 |
9 | Locked | 40.3 | 11000 | 74 |
10 | Locked | 40.9 | 10067 | 35 |
11 | Locked | 40.3 | 7986 | 127 |
12 | Locked | 40.9 | 6820 | 54 |
13 | Locked | 40.3 | 7951 | 44 |
14 | Locked | 40.3 | 8051 | 55 |
15 | Locked | 40.3 | 8251 | 56 |
16 | Locked | 40.3 | 6789 | 52 |
17 | Locked | 40.3 | 5316 | 49 |
18 | Locked | 40.3 | 4133 | 31 |
19 | Locked | 40.3 | 5247 | 29 |
20 | Locked | 40.3 | 7810 | 50 |
21 | Locked | 40.3 | 6273 | 47 |
22 | Locked | 40.9 | 4680 | 44 |
23 | Locked | 40.3 | 4008 | 41 |
24 | Locked | 40.3 | 3298 | 56 |
on 01-03-2022 21:06
1 | 39400000 | 45.8 | 5120 | 64 qam | 4 |
2 | 46200000 | 45.8 | 5120 | 64 qam | 3 |
3 | 32600000 | 46 | 5120 | 64 qam | 5 |
4 | 25800000 | 46.3 | 5120 | 64 qam | 6 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 2 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 01-03-2022 23:22
Shows errors
power cycle (off/on) the hub and recheck/repost. (Resets error counter)
