Just joined
Why does the small booster need to be plugged into the mains not an extension?
new to virgin - setting up a booster kit and just wondering if it matters that I’ve plugged the smaller on into an extension lead as the main socket closest to hub is in a cupboard. ..?
Tags (1)
  • 14.75K
  • 620
  • 1.42K
Re: Why does the small booster need to be plugged into the mains not an extension?
Ideally the wall and you need a Ethernet cable from the small booster to the hub.
Just joined
Thank you legacy 1.
I guess I’m trying to understand why this is..?
mad I mentioned the plug socket closest to the hub is in a cupboard and I don’t want it in there...
  • 113
  • 11
  • 29
some extension cables can interfere with the operation of powerline adapters (particularly those with surge protection). that's why it isn't "recommended".
