  • 6
Lamby1800
When will virgin send an engineer?
I've had on going issues with my Wi-Fi connection.
How many times must the problem be reported before an engineer is sent out?
How long does the Wifi have to be down before an engineer comes out?
  • 13.49K
  • 1.05K
  • 3.15K
Re: When will virgin send an engineer?
unless you can prove the wifi side of the hub is faulty VM will do little to nothing - they supply a connection to the hub - if that works wired then thats an end of it
wifi problems are down to the user to resolve - they will help on here but thats about it
give some details of your problems and people will help - firts thing to check is is a wired connection ok
____________________
Tony
