rossb1
Message 1 of 9
When hi join a video call my Wifi the interent connection disconects
Every time I join I video call from my laptop, the internet disconnects.  It says there is no Wifi for a few minutes.  This only happens over Wifi. I have to wait for the wifi signal to return - this can happens a number of times over a call.
The strange thing is that my other devices that use the internet continue to be connected, it's only the laptop that I use for video calls - (Webex)
This has been going on for some time and I have been told it's more likely to be something to do with Virgin, then the laptop.
Would you be able to help?
gary_dexter
  • 29.1K
  • 1.78K
  • 3.81K
Message 2 of 9
Re: When hi join a video call my Wifi the interent connection disconects
Use a wired connection instead
EvBur
Message 3 of 9
I have exactly the same problem.  I can't use a wired connection due to my company only allowing my laptop to connect via wifi.
This is making working from home very difficult and very embarrassing.
it's been getting worse each day and I've been through the forum and tried various options. even had a new HUB.
About to phone customer services and complain, again.
Ev
gary_dexter
  • 29.1K
  • 1.78K
  • 3.81K
Message 4 of 9
@EvBur wrote:
Ev
I've never heard of a LAN connection being locked out of use, especially as WiFi is more prone to interference and snooping.
EvBur
Message 5 of 9
Unfortunately it's company policy and nothing I can change.  I need to use wifi for work.
The wifi connection is very good, it just keeps coming up as no internet connection. It's dropped 6 times in the last hour.
Customer services "150" are engaged,  not a happy customer.
gary_dexter
  • 29.1K
  • 1.78K
  • 3.81K
Message 6 of 9
Do other devices lose connection as well at the same time?
EvBur
Message 7 of 9
no, PC on wired is fine and phone on the same wifi is fine, but that could be on the 2.4 network rather than 5GHz.
rossb1
Message 8 of 9
 as the router is in the front room and I work from my office, so using a wired connection will not work.   I also had my hub replaced a few months ago and it did not fix the problem.
Has anyone fixed this issue, as it looks like it's been going happening to others for over a year now.
do you think it could be related to the number of devices connected to the hub,
gary_dexter
  • 29.1K
  • 1.78K
  • 3.81K
Message 9 of 9
We don't even know it's the same issue as the thread was somewhat hijacked by another poster.
