Message 1 of 9
WhatsApp and Snapchat not working correctly
Hey guys. My parents have decided to put child safe on my phone and suddenly my WhatsApp not Snapchat is working correctly. For what’s app I have to wait about a minute or two just for it to connect and also WhatsApp doesn’t want to work when I have background app refresh on. For Snapchat it just doesn’t work completely. I just want to see if there’s anything I can do because my parents say that both the apps aren’t blocked but I feel like something must of been turned on by accident that both of the apps aren’t working correctly for me. Also I have an iPhone 6s if it helps by any chance
  • 24.87K
  • 1.43K
  • 3.16K
Message 2 of 9
Re: WhatsApp and Snapchat not working correctly
If they’ve turned childsafe on it blocks them.
Message 3 of 9
The weird thing is that WhatsApp is still working but not properly. I can text and call I just get not notifications if someone texts or calls me
  • 11.99K
  • 934
  • 1.53K
Message 4 of 9
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Message 5 of 9
I checked and it shows 215mbps and 17ping. 4G and a hub 3.0
  • 11.99K
  • 934
  • 1.53K
Message 6 of 9
Then
Can you please
Mike Robinson
  • 24.87K
  • 1.43K
  • 3.16K
Message 7 of 9
What does that have to do with child safe blocking websites and applications?
Message 8 of 9
I’m just confused because apparently the childsafe is out on WiFi so everyone will have childsafe. The thing what I’m confused about is that it’s just me who’s WhatsApp and Snapchat isn’t working.
  • 24.87K
  • 1.43K
  • 3.16K
Message 9 of 9
No idea.
You say your parents enabled it - maybe ask them.
