Hello
If you got a web browser and login too ttp://192.168.0.1 Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
The password is on the base of the hub.
When you are in click in Admin on left and when it refreshes goto info.
There you are looking for a line like
Software version | : 9.1.1912.304 |
The firmware is pushed out by Virgin media automatically normally sometimes between midnight and 2am, if there is one and it is done in a phased push. There is checking on the system to allow you to check for a release as that isnt a function of the hub.
The one listed for me is the latest.
Regards Mike
