What is going on with cable broadband?
Aszrayel
My cable broadband has been down most of the day. Basically it’s up and down like a tarts draws. We get spurts of download which vary wildly and the upload speed is back to the mid 90’s 33k modem speeds.
Both myself and my wife have lost a full day of working from home.
Yes we have rebooted the router multiple times, tv is fine but the internet is appalling.
I am having to use my mobile to post this.
18 REPLIES 18
japitts
Assuming these issues are happening with Ethernet cable connections.. (if not, you need to check this isn't a wireless issue)
Is anything reported on the local status line? 0800 5610061 often lists known network issues down to street/postcode level.
Do you have a BQM running? Free, takes 5-10minutes to setup and monitors your connection 24/7 providing excellent evidence of any network issues.
Aszrayel
Hi thanks for the reply. Tried then phone number. Reporting no issues. Loaded the Virgin phone app, ran the test and it said you need to login to your account online to properly diagnose the issue. Did that from my phone and PC and I just get a page stating “Ops something is broken”.
any further advice/help would be greatfully appreciated.
japitts
So if you connect a laptop/PC to your hub via Ethernet cable and tested, what speeds are you getting?
Have you setup the BQM?
Aszrayel
Hi. Yeah, my PC and Laptop are both wired directly to the router. On a speedtest download speed varies between 50-350mbs wildly. Upload speeds are stuck between 0.01-0.12mbs. It's impossible to use most of the time. I've set BQM up, I'm not sure how to attach the screen shot. But it shows a lot of dropped packets, Max Latency varies between 30-120ms.
A loose connection or damaged cable can do this. So, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box.
Aszrayel
Aszrayel
I also found a load of these errors in the router Network log:
0/07/2021 15:40:40 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Post up all the data - copy/paste as “Formatted Text” (not images) 3 FULL sets of data onto here – 2 pages from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
402750000
-6
38
256 qam
30
2
202750000
-3.2
40
256 qam
9
3
210750000
-3.5
40
256 qam
10
4
218750000
-3.5
40
256 qam
11
5
226750000
-3.5
40
256 qam
12
6
234750000
-3.5
40
256 qam
13
7
242750000
-3.7
40
256 qam
14
8
250750000
-3.7
40
256 qam
15
9
258750000
-3.7
40
256 qam
16
10
266750000
-4
40
256 qam
17
11
274750000
-4.2
40
256 qam
18
12
282750000
-4
40
256 qam
19
13
290750000
-4.4
40
256 qam
20
14
298750000
-4.4
40
256 qam
21
15
306750000
-4.2
40
256 qam
22
16
314750000
-4.4
40
256 qam
23
17
322750000
-4.5
40
256 qam
24
18
330750000
-4.5
40
256 qam
25
19
370750000
-5.7
40
256 qam
26
20
378750000
-5.7
38
256 qam
27
21
386750000
-6.2
40
256 qam
28
22
394750000
-6
40
256 qam
29
23
410750000
-6
38
256 qam
31
24
418750000
-6
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
5
0
2
Locked
40.9
4
0
3
Locked
40.9
7
0
4
Locked
40.3
6
0
5
Locked
40.3
5
0
6
Locked
40.3
5
0
7
Locked
40.3
4
0
8
Locked
40.3
0
0
9
Locked
40.3
5
0
10
Locked
40.9
7
0
11
Locked
40.3
5
0
12
Locked
40.3
7
0
13
Locked
40.3
5
0
14
Locked
40.3
0
0
15
Locked
40.3
6
0
16
Locked
40.3
5
0
17
Locked
40.3
15
0
18
Locked
40.3
11
0
19
Locked
40.3
6
0
20
Locked
38.9
5
0
21
Locked
40.3
6
0
22
Locked
40.9
4
0
23
Locked
38.9
5
0
24
Locked
40.3
12
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300000
44.3
5120
64 qam
1
2
39400000
43.8
5120
64 qam
4
3
46200000
44.3
5120
64 qam
3
4
53700000
45.3
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
5
0
2
ATDMA
0
0
1
0
3
ATDMA
0
0
3
0
4
ATDMA
0
0
6
0
Time
Priority
Description
10/07/2021 15:40:40
critical
10/07/2021 15:38:11
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/07/2021 14:58:26
critical
10/07/2021 14:41:51
notice
09/07/2021 16:19:32
critical
09/07/2021 16:14:22
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/07/2021 15:33:17
critical
09/07/2021 15:32:15
notice
09/07/2021 12:43:30
critical
09/07/2021 12:39:51
Warning!
06/07/2021 08:15:36
critical
06/07/2021 01:15:15
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/07/2021 01:15:15
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/07/2021 17:32:37
critical
02/07/2021 13:15:15
notice
02/07/2021 13:15:15
Error
30/06/2021 09:51:49
critical
29/06/2021 01:15:15
notice
29/06/2021 01:15:15
Error
27/06/2021 02:45:40
critical
