Weekly connection drops
Anonymous
Not applicable
Hello,
On a weekly basis my internet connection briefly drops during the day. I notice this because I will be working on my laptop (connected via Ethernet) and either my Teams call or something else that relies on an Internet connection will stop working. This seems to coincide with this error:
16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
I called the number to check for faults in the area and apparently there are no issues. I also checked the stats on my hub and everything looks normal to me.
I've ended up having to force my work laptop to use my backup connection with BT, as this connection is very reliable.
Any help is appreciated. My hub is in modem mode. Would it help if I factory reset it?
Here is the info from my Hub:
24-07-2023 20:06:24noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2023 20:01:20noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2023 19:33:51noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2023 17:26:19noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2023 17:26:07criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2023 17:26:07critical16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
24-07-2023 17:24:59criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-07-2023 21:50:17noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-07-2023 18:38:51noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-07-2023 18:14:05noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-07-2023 18:09:02noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-07-2023 12:28:47errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
23-07-2023 04:53:14criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-07-2023 10:47:07noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-07-2023 10:42:04noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-07-2023 10:08:20noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-07-2023 10:03:17noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-07-2023 09:13:05noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
21-07-2023 08:09:16noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-07-2023 22:42:59noticeREGISTRATION COMPLETE - Waiting for Operational status
20-07-2023 22:42:56noticeUS profile assignment change. US Chan ID: 12; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-07-2023 22:42:51noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-07-2023 22:42:48noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-07-2023 22:42:46warningToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-07-2023 22:42:45warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-07-2023 22:42:43noticeHonoring MDD; IP provisioning mode = IPv4
20-07-2023 22:42:35criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-07-2023 22:42:18criticalCable Modem reboot from UI
20-07-2023 22:35:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-07-2023 22:35:10criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-07-2023 22:35:02criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
20-07-2023 22:35:01criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
1467000000341QAM 2568
24510000003.840QAM 2566
34590000003.240QAM 2567
44750000003.340QAM 2569
54830000003.540QAM 25610
64910000003.740QAM 25611
74990000003.941QAM 25612
85070000003.841QAM 25613
95150000003.741QAM 25614
105230000003.641QAM 25615
115310000003.741QAM 25616
125390000003.741QAM 25617
135470000003.641QAM 25618
145550000003.741QAM 25619
155630000003.641QAM 25620
165710000003.741QAM 25621
175790000003.641QAM 25622
185870000003.441QAM 25623
195950000003.441QAM 25624
206030000003.341QAM 25625
21611000000341QAM 25626
226190000002.941QAM 25627
236270000002.941QAM 25628
24635000000341QAM 25629
256430000003.241QAM 25630
266510000003.241QAM 25631
276590000003.241QAM 25632
286670000003.441QAM 25634
296750000003.340QAM 25635
306830000002.941QAM 25636
316910000002.741QAM 25637
1Locked41170
2Locked40200
3Locked40290
4Locked40250
5Locked40240
6Locked40190
7Locked41190
8Locked41220
9Locked41180
10Locked41230
11Locked41290
12Locked41260
13Locked41310
14Locked41240
15Locked41200
16Locked41260
17Locked41240
18Locked41400
19Locked41360
20Locked41430
21Locked41430
22Locked41520
23Locked41460
24Locked41470
25Locked41380
26Locked41430
27Locked41390
28Locked41280
29Locked40270
30Locked41210
31Locked41340
04960000044.55120QAM 641
143100000445120QAM 642
23660000043.55120QAM 643
330100000435120QAM 644
42360000042.85120QAM 645
0ATDMA0000
3ATDMA0000
4ATDMA0010
6 REPLIES 6
Legend
Make sure the laptop is using a Power Profile that is Always On for a Teams Call. Often it is the laptop's power management that is pausing the network adaptor or Wi-Fi causing the conf calls or VPNs to suffer drop outs.
So if you are using modem mode, you only have one laptop wired into the Hub?
Anonymous
Not applicable
No, I use my own router and my laptop is connected to that via Ethernet.
Joseph_B
Hey @Anonymous,
Welcome back to the Community Forums and thanks for the post.
Sorry to hear you have been having this issue, when your router is in Modem mode we are limited in the diagnostics we can run, we would advise putting this back in Router mode if you would like to discuss this so we can run some tests with you we can.
Joe
Anonymous
Not applicable
Thanks for your reply. To be honest, I am so fed up with the instability of the service I am going to cancel. Tonight I had another drop out . . . .
31-07-2023 23:31:02criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:31:02criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:31:02critical16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:30:52criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:30:52critical16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:24:13criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:24:10warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:24:08noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:24:08noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 6 7 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 34 35 36 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=
31-07-2023 23:24:08noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:24:08noticeCM-STATUS message sent. Event Type Code: 23; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:24:07criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:24:04criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:24:02noticeCM-STATUS message sent. Event Type Code: 4; Chan ID: 6 7 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-Q
31-07-2023 23:23:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:23:50criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:23:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:23:36criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:23:14criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:23:13criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:22:25criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:22:18warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:22:11warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:22:11criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
31-07-2023 23:22:06criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Hi fibrejay,
I'm sorry to hear you experienced another connection drop last night.
I've had a look at this end and whilst most of your signal levels are normal, there are still some abnormalities which will need investigating.
I've dropped you a private message so I can look into getting an engineer sent out to you.
Beth
