Anders821
Weak Wifi - Home
Recently been experiencing weak WiFi across the house. Been in the house 3 years and always had the hub 3. This is end terrace so not massive. Weak signal in kitchen, bathroom and 2 bedrooms. The hub has been in the same spot all the while. No issues with lab connection. Had the automated test perform and no issues found. Any ideas what would cause the degraded WiFi signal all of a sudden. Any suggestions to improve, router has been reset etc but that not made an improvement.
thanks in advance
tehwolf
  • 1.52K
  • 243
  • 367
Superfast
Re: Weak Wifi - Home
It could be that there's more RF interference in your area than there was previously - you can investigate this yourself using something like inSSIDer for PC (or other equivalents on android etc..)
That said, the hub is a poor device and the best option is usually to purchase a 3rd party router and use that.
