Weak Signal and crashes
Stephen090704
Hello, around a month ago we switched from Trooli to Virgin Media, since then we've had nothing but issues on a daily basis, the wifi package we brought was the 276mbps package. We're experiencing weak signals across the house aswell as the wifi crashing, my parents had spoken to virgin media multiple times including ordering range extenders. Apon running diagnostics it had stated that every single device in our house had poor signal, We also noticed quite a few errors in the networking logs, we believe that a new router is needed, we're considering just buying a router instead as we've been running into issues daily.
Router: Hub 3
I blurred some things out such as the MAC addresses.
8 REPLIES 8
Re. the Atom Error messages  See messages 4 and 8 in here
https://community.virginmedia.com/t5/Networking-and-WiFi/NOTICE-ATOM-is-restarted-due-to-Kernel-oops...
I think your only hope is to get it replaced by a Hub4 or Hub5.  Or perhaps stick the Hub into modem mode and get your own better quality wireless router or Mesh.
Would be worth posting up the Hub data - as per the other posts in that thread so we can take a look.
Stephen090704
Hey there, sorry for the delayed response, here you go hopefully this helps.
Legend
I would avoid renting the VM Pods if that means facing a bill hike of £8 each per VM Pod.
if you are paying far better options are available that remain your property and would work with any ISPs Hub or Router.
Hey there, the VM pods are unrelated to the issues I'm having, We're under volt so we don't pay any extra, however I need someone who has the expertise to analyse the data I recently sent above to determine what's wrong.
Hi Stephen090704,
Thank you for your post and welcome to our community.
I am sorry to hear about the service issues you are having.
Are you using the hub in modem mode?
Do you have our connect app?
Please pop back to us when you can.
Vikki - Forum Team
Legend
The Downstream channels look normal.
The Upstream Power levels are all well outside of the preferred range.
Hub Signal Level Checks
Via http://192.168.0.1/ connect to the Hub in Router mode, do not login in, scroll down to "Check router status"     Use http://192.168.100.1/ for a Hub in Modem mode
Using the Hub's "Check router status" tabs check the Downstream and Upstream power levels are in spec.
Downstream Power Levels of -7 to +7 dBmV are preferred, +10dBmV is the max acceptable, with a SNR of 33dB or higher across all DOCSIS 3.0 channels. Rising error counts across many channels is a current service noise fault.
Upstream
Power Levels of 35 to 49 dBmV are preferred, with QAM 64 Modulation mode across all four to six DOCSIS 3.0 channels.  Seeing QAM 32/16/QPSK is a current service noise fault.
The router is not in modem mode and the app displays weak signal on every device.
Thanks for coming back to us @Stephen090704.
I understand that you have since been able to speak to our team since your most recent post.
Can you please confirm if this has since been resolved following on from this interaction, or if this is still ongoing?
Thanks.
David_Bn
