risc19
  • 849
  • 27
  • 253
Well-informed
Message 1 of 21
Wan link aggregation hub4
Does anyone with more experience than me know if the hub4 allows link aggregation now?
I had no luck in modem mode, but I did mange a connection when setup as dual wan.
However that’s not exactly an ideal way to do it.
If it doesn’t, that means it’s basically impossible to get beyond 950mb on a wired connection?
That leaves 150mb unusable.
Thanks for any input.
My Broadband Ping - Virgin Lagfest Modem Mode
gary_dexter
  • 32.63K
  • 2.01K
  • 4.46K
Message 2 of 21
Re: Wan link aggregation hub4
Apparently it can be done - there was a post about it on cableforum:
https://www.cableforum.uk/board/showthread.php?t=33709413
Blueyonderer
  • 78
  • 31
Up to speed
Message 3 of 21
Yes it's possible but you need a router that supports round-robin link aggregation - I don't think it works with static link aggregation. This feature is usually only found on business class routers. I'm running a Mikrotik CCR1009-7G-1C-1S+ and I'm getting full wired speed with the Hub 4 in modem mode with 4 LAN cables between the hub and the router (although it works with two, just fine).
Edit: I just double-checked my router config and the bonding type is set as 'balance rr' with ether1 - ether4 configured as the slave ports (I read somewhere that having 4 ports connected is more reliable than 2 and I've had no issue whatsoever with link speed/reliability since I set it up).
Here's a recent speedtest result:
  • 5.62K
  • 462
  • 1.42K
Message 4 of 21
@Blueyonderer wrote:
Yes it's possible but you need a router that supports round-robin link aggregation - I don't think it works with static link aggregation. This feature is usually only found on business class routers. I'm running a Mikrotik CCR1009-7G-1C-1S+  <snip>
That's a nice piece of hardware 🙂
Blueyonderer
  • 78
  • 31
Up to speed
Message 5 of 21
I always used to use Netgear ProSafe routers then switched to Asus a few years ago but I wanted something a bit more future-proof and reliable for the current working from home situation so I opted to upgrade to the Miktrotik. It's probably overkill but it has been completely reliable so far so I'm happy with it.
...plus I like lots of flashing lights 😁
risc19
  • 849
  • 27
  • 253
Well-informed
Message 6 of 21
May I ask if that was in modem mode?
Im just unsure if two lan ports can be active except in router mode.
I can set link aggregation with wan and lan 4 but it fails every time.
Dual wan works in balance rr but only when hub is on router mode. Then I have the added complication of getting everything else to be happy.
Blueyonderer
  • 78
  • 31
Up to speed
Message 7 of 21
Yes, my hub 4 is definitely in modem mode - using link aggregation all four LAN ports can be used simultaneously.
Here's a snippet from my router config, in case it's of use:WANBond.PNG
Edit: I think I might have had to reboot the hub, then power up the router once the hub was up to get them working together initially.
Another Edit: The ability to use multiple LAN ports in modem mode to support link aggregation was only introduced after a particular firmware version (exactly which/when escapes me).
risc19
  • 849
  • 27
  • 253
Well-informed
Message 8 of 21
@Blueyonderer
Thank you, this is super helpful.
I may give it another go.
Thanks again.
Blueyonderer
  • 78
  • 31
Up to speed
Message 9 of 21
Happy to help.
I'd be interested to hear if you get it all working OK.
risc19
  • 849
  • 27
  • 253
Well-informed
Message 10 of 21
Nope!
I gave up.
Wan aggregation was a fail despite trying a thousand times with various settings/reboots.
Dual wan- balanced worked!
But caused so many dhcp problems I gave up on that too.
If only they had just put one 2.5g port on the hub 4.
Ah well.
Thanks for all your help folks.
