Message 1 of 8
WPS PIN not recognised
I am trying to access my Superhub router using the details on the back of the device. I have 100% entered the password and PIN correcly but I get a pop-up saying "WPS PIN is not recognised. Please try again."
I have used the reset pin button multiple times, holding it down for well over 10 seconds. The lights flash and it appears to be resetting but it has not fixed the issue with the WPS PIN.
I can't access the settings of my router because of this issue. It is not a recent change, it has been like this for years until I gave up on it but now I need to get access to the settings.
Appreciate any help/suggestions!
Tags (2)
  • 24.72K
  • 1.43K
  • 3.15K
Message 2 of 8
Re: WPS PIN not recognised
The WPS PIN isn’t the admin password
Message 3 of 8
The login page specifically asks for the WPS PIN as well as the password:
  • 21.1K
  • 2.27K
  • 4.2K
Message 4 of 8
Yup. Some of the older Super Hubs asked for both.
Not sure there is any fix if it doesn't work though even after a reset apart from a replacement.
  • 24.72K
  • 1.43K
  • 3.15K
Message 5 of 8
Have you done a 60 second pinhole reset?
Message 6 of 8
Yes I've tried the 60 sec reset but it's not made a difference sadly
Message 7 of 8
What is the best way to get a replacement during these covid times? I've heard the wait times to 150 are very long
  • 11.83K
  • 925
  • 1.52K
Message 8 of 8
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
