WPS Bug is STILL present in Hub 3 - FIVE YEARS LATER????
deans6571
Wise owl
I used my WPS button last night to connect my printer and after the connections had been made, the wifi green light on my Hub 3 continued to flash for hours.
Nothing I could do would stop it from flashing other than turning off the WPS function in the settings and then rebooting my Hub.
I am pretty shocked that this bug is STILL in the Hub 3 firmware as reported in 2018:
Solved: VM Hub 3.0 Flashing Green WiFi light - Virgin Media Community - 3750146
Here we are FIVE years later and nothing has been done to rectify this??!
__________________________________________________________
Husband, Dad, Gamer, Gadget Lover......
Twitter: @deans6571
2 REPLIES 2
Yet another reason for modem mode and your own kit.  I’ve never used WPS and never intend to btw.
We keep WPS disabled on our Hub 3
