Alan865
Message 1 of 5
WIFI mesh
Setting up tp-link AC1200 Deco M4, need to find out what type of Internet connection type.
Dynamic IP, PPPoE, Static IP, L2TP, PPTP, DS-Lite?
gary_dexter
  • 29K
  • 1.77K
  • 3.79K
Message 2 of 5
Re: WIFI mesh
Dynamic IP
And make sure you put the hub into Modem Mode
Alan865
Message 3 of 5
Re: WIFI mesh
Thanks Gary do you have a link to change hub to modem mode? Did see it earlier but can’t find it now?
gary_dexter
  • 29K
  • 1.77K
  • 3.79K
Message 4 of 5
Re: WIFI mesh
You need to login to the hubs admin pages and change it there.
You then need to power off the hub and mesh system.
Then power on just the hub with nothing connected to it and wait 5 minutes.
Connect the mesh to the hub by Ethernet then power the mesh system on and wait 5 minutes again.
It should then all be working. Any further Ethernet connections need to be made to the mesh system and not the hub.
Alan865
Message 5 of 5
Re: WIFI mesh
Thanks for your help Gary, as soon as I changed to Modem tp-link app worked and set up mesh perfectly. 🤙
