Been having problems with WIFI on the superhub 3 for ages. Had seemed to be ok recently but now it's messing about yet again
I noticed it was very slow so ran a speed test on my phone and got bareley 2mb download speed. Tried tablet that kept on coming up connected but no internet access
So I rebooted the hub, which usually fixes the problem but not this time. Kept getting that same connected with no internet access error on both phone and tablet. Disabled MAC address filtering (which I have used like forever with no problems) and cleared all the devices out of the list. I can now get both to connect but nothing really happens can't even load google the connection times out. Normally I leave the 2.4GHZ turned off but I have turned it back on now to see if I can get that to work. The tablet connects to the 5GHZ first then when it can't load the page it switches to the 2.4GHZ which is unreliable too. Worked fine to start with, Got a 50mb speed on the test but then it just went really slow again after about 5 minutes
I can only assume the superhub is knackered and needs to be replaced ?
