  • 1.42K
  • 110
  • 203
Knows their stuff
Message 11 of 22
Re: WIFI intermittent
If your power levels are wrong or you have interference or SNR issues then you will have intermittant dropouts, this is what those figures are for, but if you don't wish to post them that's fine.
Once you know those figures are good then you can start messing with the WiFi configuration, but it's pointless changing that until you know your main connection is ok.
  • 36
Message 12 of 22
well thats not entirely true is Gary, and you also asked me for the same logs and then never replied... so not sure  what use uploading them was. When I ran diagnostics  on mine over the course of several days it  came back and said it had problems with the ethernet connections and the phoneline. This then disappeared and then came back. I know there is a problem with the wifi as one device might work yet another in the same room doesn't. There are 2 wired power connectors  one which the the ethernet connected goes into device that will work one day and then later it will drop not connect and then all wifi goes.
  • 25.14K
  • 1.44K
  • 3.2K
Message 13 of 22
But, with all due respect, this isn't your thread and therefore not the same issue as you are having.
  • 10
Message 14 of 22
  • 10
Message 15 of 22
I cant see anything that says Router Status. Do I need to use the diagnostic tool, or is it the status overview you need?
  • 12.27K
  • 950
  • 1.57K
Message 16 of 22
If you haven't logged into the Hub previously (or reset to factory) you will need to login and go through the initial procedure, it only takes a couple of minutes.
Once done, log out and the page should look similar to this (Hub 3 illustrated).
Router-Status-01
Mike Robinson
  • 10
Message 17 of 22
Sorry to be a pain,but I cant remember my password to login, is there a way I can reset it?
  • 12.27K
  • 950
  • 1.57K
Message 18 of 22
If you can't see the 'Check Router Status' text it means that your Hub is at Factory default mode and the password on the base of the Hub will be correct.
Hub-3-Password
Mike Robinson
  • 10
Message 19 of 22
124300000011.540256 qam14
220300000012.540256 qam9
321100000012.540256 qam10
421900000012.540256 qam11
52270000001240256 qam12
623500000011.940256 qam13
725100000011.540256 qam15
825900000011.940256 qam16
926700000012.540256 qam17
102750000001340256 qam18
1128300000013.440256 qam19
1229100000013.140256 qam20
1329900000013.540256 qam21
1430700000013.640256 qam22
1531500000013.540256 qam23
1632300000013.340256 qam24
1733100000013.540256 qam25
183710000001440256 qam26
193790000001440256 qam27
2038700000013.440256 qam28
213950000001340256 qam29
2240300000013.340256 qam30
2341100000013.640256 qam31
2441900000013.540256 qam32
1Locked40.3380
2Locked40.9440
3Locked40.3440
4Locked40.3270
5Locked40.9470
6Locked40.9340
7Locked40.3310
8Locked40.3650
9Locked40.3560
10Locked40.3290
11Locked40.9410
12Locked40.3530
13Locked40.3780
14Locked40.3520
15Locked40.3730
16Locked40.3770
17Locked40.3250
18Locked40.3480
19Locked40.3520
20Locked40.3490
21Locked40.37214
22Locked40.3590
23Locked40.3570
24Locked40.3590
  • 10
Message 20 of 22
13940000042.8512064 qam2
22579998141.3512064 qam4
33259998642.8512064 qam3
44620000442.8512064 qam1
1ATDMA0010
2ATDMA0030
3ATDMA0010
4ATDMA0000
