  • 32
Message 1 of 10
WIFI Slow
As of yesterday our wifi has gone incredibly slow, I have 100Mbps connection. and i am getting between 8 to 12 Mbps. i have done a reset. my son is getting 86 Mbps on his ps4 via ethernet.
so the speed is there it must be a wifi problem. does anyone have a solution for this ??
  • 6.49K
  • 484
  • 856
Hero
Message 2 of 10
Re: WIFI Slow
Nowhere near enough information even to make a wild guess, can you answer a few questions please ...
WiFidevice that you are  connecting on WiFi ?
Location of device in relation to the Hub ?
Is the device running on 2.4GHz or 5GHz ?
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 32
Message 3 of 10
Re: WIFI Slow
Its Ok all back to normal now. came back around 6AM this morning. Cheers
  • 32
Message 4 of 10
Re: WIFI Slow
Ok so back to slow speeds again . also 2.4ghz drops every couple of days and needs a reset. This is on every device. Phone firestick laptop 5ghz. And 2.4fhz all dropping down to between 6 to 12Mbps. Like im being throttled or something . if this carrys on its got to be a isp change im thinking talk talk . any help would be appreciated.
  • 30.3K
  • 1.51K
  • 5.26K
Message 5 of 10
Re: WIFI Slow
test with a wired connection if you are getting full speeds then its a local wifi problem. The best way to fix that is a better wifi router/AP of your own
  • 1.54K
  • 60
  • 119
Message 6 of 10
Re: WIFI Slow
Hi deltadax,
Thanks for getting in touch.
I am sorry to read that the speeds have dropped again.
I can see that @apcyberax has suggested a speed test via a wired connection. Once you have done this would you please post the results to this thread for me?
Thank you
Nat
  • 32
Message 7 of 10
Re: WIFI Slow
Laptop wired. Have been getting no more than 20Mbps. All night Just checked again now 1020am and getting 85. And now getting 110Mbps again on firestick. It seems To be between. 5-6pm and 10am that speeds are dropping. ??
  • 1.54K
  • 60
  • 119
Message 8 of 10
Re: WIFI Slow
Thank you.
This may be due to peak times in your area. Could you monitor this over the next 48 hours and see if the issues only happen during those specified times?
You may want to use a broadband quality monitor during the observation.
Let us know the results and we will be happy to assist further.
Nat
  • 32
Message 9 of 10
Re: WIFI Slow
Will do that. But i cant imagine peak times to be 3am 4am in the morning.
  • 6.49K
  • 484
  • 856
Hero
Message 10 of 10
Re: WIFI Slow
Probably time to set up a BQM at thinkbroadband.com - this will give you an insight into what is happening with the signal coming into the property, it will take a few hours to get any kind of trend showing.
Mike Robinson
