on 20-07-2021 16:40
Hi, Our wifi pod stopped working last week. Spent over 1 hour on the phone to Tech Support. We have tried everything to get back working but think it has developed a fault. They Were very helpful and tried to order another one but system was not letting her. She phoned me back within the hour and tried again. Was meant to call me back Monday but have not had a call. If any Virgin Staff are can help that would be great?
20-07-2021 16:46 - edited 20-07-2021 16:47
You should look at other ways to do wireless as VM are in over their heads with these pods so look at getting your own wireless router with 1Gb ports and use the hub in modem mode.
on 20-07-2021 17:12
on 20-07-2021 17:40
It has a fan in apparently.
on 21-07-2021 08:49
No fan in the model I have.
21-07-2021 11:30 - edited 21-07-2021 11:39
Do you have the new Hex shaped pods and if so does it have 2 Ethernet ports on it?
I only read this last week, I did not know they had a fan and still do not know for sure as I have one here.
on 21-07-2021 11:49
Yes thats correct. I was a tester for them a while back. No fan in these. They do seem to attract lots of dust inside
on 21-07-2021 12:56
I was tester also, I know the SuperPod (the model with 2 ports) runs hot and made sense it would have a fan in it and it may well do if its attracting so much dust.
I will try and find out for sure.
