WIFI PROBLEMS IDENTIFIED ON NETWORK SCAN. LOTS OF LOW SIGNALS AND WIFI KEEPS DROPPING
Hi there
I am new to Virgin. Just signed up for the broadband for increased speeds.
I’m a skyQ user.
Since installation various problems with WPS not turning off ( constant flashing light) and devices dropping off the network.
When it works it works but the constant drops in service are causing major issues.
  • 47
  • 8
  • 8
Dialled in
Re: WIFI PROBLEMS IDENTIFIED ON NETWORK SCAN. LOTS OF LOW SIGNALS AND WIFI KEEPS DROPPING
If you have skq Q mini boxes then the main SKY Q unit will connect to the Wifi on the 2.4Ghz band to the Hub. The Sky Q units set up a private network on 5Ghz between themselves which you should see on 5ghz wifi somewhere arount 34, 36, 38 etc not into the Hundreds though.
If you have scanned and have skyQ mini boxes then look at the 2.4Ghz band only. Normall you will find the channel 1,3,6,9 and poss 11 are the ones mainly used. If you stand next to the Hub you should see your WiFi as the one with the highest peak, that should correspond to the channels above.  Normally the HUB will change to a channel that is the least used to give you the best bservice.
This is really to give you a better insite into what you are seeing.
With you original information there is not enough info to really assis you further without more information
KK
thanks for the response.
here are the stats If that helps ?
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
251000000
7.1
38
256 qam
15
2
139000000
8.6
38
256 qam
1
3
147000000
8.5
38
256 qam
2
4
155000000
8.1
38
256 qam
3
5
163000000
8
38
256 qam
4
6
171000000
8
38
256 qam
5
7
179000000
7.9
38
256 qam
6
8
187000000
7.9
38
256 qam
7
9
195000000
7.5
38
256 qam
8
10
203000000
7.5
38
256 qam
9
11
211000000
7.4
38
256 qam
10
12
219000000
7.5
38
256 qam
11
13
227000000
7.4
38
256 qam
12
14
235000000
7.1
38
256 qam
13
15
243000000
7.1
38
256 qam
14
16
259000000
7.1
38
256 qam
16
17
267000000
6.9
38
256 qam
17
18
275000000
6.6
38
256 qam
18
19
283000000
6.9
38
256 qam
19
20
291000000
7.1
38
256 qam
20
21
299000000
7.3
38
256 qam
21
22
307000000
6.8
38
256 qam
22
23
315000000
6.6
38
256 qam
23
24
323000000
6.8
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
5
0
2
Locked
38.9
6
0
3
Locked
38.9
4
0
4
Locked
38.9
19
0
5
Locked
38.9
19
0
6
Locked
38.9
18
0
7
Locked
38.9
18
0
8
Locked
38.9
17
0
9
Locked
38.6
5
0
10
Locked
38.6
6
0
11
Locked
38.9
5
0
12
Locked
38.6
3
0
13
Locked
38.6
6
0
14
Locked
38.6
4
0
15
Locked
38.6
8
0
16
Locked
38.9
5
0
17
Locked
38.6
3
0
18
Locked
38.9
7
0
19
Locked
38.6
4
0
20
Locked
38.6
5
0
21
Locked
38.6
3
0
22
Locked
38.6
5
0
23
Locked
38.6
6
0
24
Locked
38.6
4
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700026
3.65
5120
64 qam
2
2
39400000
3.621
5120
16 qam
4
3
46199976
3.65
5120
64 qam
3
4
60300021
3.65
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
07/05/2020 09:33:29
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/05/2020 04:39:40
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/05/2020 04:39:40
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/05/2020 04:39:39
Warning!
07/05/2020 04:39:39
critical
07/05/2020 04:39:37
Warning!
07/05/2020 04:39:37
critical
06/05/2020 23:03:21
notice
06/05/2020 22:59:26
critical
06/05/2020 12:17:15
notice
05/05/2020 21:26:9
critical
04/05/2020 13:56:32
notice
04/05/2020 10:19:38
notice
SW download Successful - Via Config file
04/05/2020 10:16:52
notice
SW Download INIT - Via Config file
04/05/2020 10:16:42
Error
Disruption during SW download - Power Failure
04/05/2020 10:13:57
notice
  • 20.96K
  • 1.13K
  • 2.7K
Stats are a tad off there.
I would wait for a mod or tech to confirm though.
Thanks. I will wait and see who responds.
reading other threads I’m wondering I’d the skyq is clashing with the hub. Signal is brilliant 1 minute and terrible (or not working at all) the next.
Anyone have any thoughts on this issue?
wifi still keeps dropping and I’m still getting critical warnings when I scan
