james315
  • 14
Message 1 of 41
WIFI Keeps Dropping Out
My Wifi Drops out at random times throughout the day. log below
11/01/2021 18:47:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 18:40:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 14:44:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 14:16:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 13:39:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 00:32:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 22:41:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 22:41:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 22:41:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 15:33:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 15:33:29criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 15:33:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 15:33:19criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 15:33:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 15:33:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 15:32:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 15:32:58criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 15:32:58Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 15:32:56criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (3)
sophist
  • 2.7K
  • 433
  • 718
Trouble shooter
Message 2 of 41
Re: WIFI Keeps Dropping Out
does it also drop out when you're connected via an ethernet cable?
Andrew-G
  • 10.42K
  • 1.66K
  • 4.76K
Message 3 of 41
It's not the wifi, it's your broadband connection.  All those RCS Partial Service errors are the hub losing one or more channels, leading to slowdowns and dropouts.  Post the contents of the tabs titled Downstream and Upstream, chances are this is a power or noise problem, and fingers crossed they are usually easy fixes for the field team.
james315
  • 14
Message 4 of 41
  Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
16030015639.8512064 qam1
23940015039.5512064 qam4
34620000039.5512064 qam3
45370020839.5512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0040
2ATDMA0030
3ATDMA0010
4ATDMA0010
    Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1139000000-1.535256 qam1
2147000000-1.736256 qam2
3155000000-235256 qam3
4163000000-2.236256 qam4
5171000000-2.236256 qam5
6179000000-2.536256 qam6
7187000000-2.736256 qam7
8195000000-2.936256 qam8
9203000000-3.236256 qam9
10211000000-3.536256 qam10
11219000000-3.436256 qam11
12227000000-3.436256 qam12
13235000000-3.736256 qam13
14243000000-3.736256 qam14
15251000000-3.536256 qam15
16259000000-3.736256 qam16
17267000000-3.736256 qam17
18275000000-3.536256 qam18
19283000000-3.236256 qam19
20291000000-2.536256 qam20
21299000000-1.736256 qam21
22307000000-1.936256 qam22
23315000000-236256 qam23
24323000000-236256 qam24
1Locked35.73612228557
2Locked36.6860634615
3Locked35.7537234378
4Locked36.3449935803
5Locked36.6422931399
6Locked36.3510328326
7Locked36.3263627379
8Locked36.3326624239
9Locked36.3387325702
10Locked36.6384929006
11Locked36.3677850514
12Locked36.31975146124
13Locked36.34464072724
14Locked36.33957648585
15Locked36.3380188880
16Locked36.34300112115
17Locked36.34762013136
18Locked36.35591418283
19Locked36.35285823367
20Locked36.33264515696
21Locked36.62283220105
22Locked36.62102611217
23Locked36.6146624605
24Locked36.6322285216
james315
  • 14
Message 5 of 41
No etherent is not effected its Wifi only
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.96K
Message 6 of 41
May I advise you to download and install a Wi-Fi analyser to show if there are any foreign Wi-Fi broadcasts interfering with your own Wi-Fi signals. From there you can look at refining your own Wi-Fi broadcasts.
I use this one ...
WiFi Analyzer Premium - Apps on Google Play
wifi-analyser-2
wifi-2
Andrew-G
  • 10.42K
  • 1.66K
  • 4.76K
Message 7 of 41
The downstream channels have high uncorrected error counts, the power levels are within limits but on the low side for several channels, there's a spattering of T3 timeouts affecting all upstream channels, and the network log shows repeated channel loss errors.  Whether you notice or not that WILL affect all wifi and all ethernet connected devices.  It is possible that you have a wifi problem in addition to the broadband issues, I'll let @MikeRobbo guide you through that side of things.
In order to try and fix the errors I can see, my suggestion is to do a pinhole reset of the Hub, and see if that improves things, and (whether it seems to or not) to repost the network log, upstream and downstream data after 24 hours continuous run time.
james315
  • 14
Message 8 of 41
Hello thanks for your suggestons, I have done the pin hole reset but i still have the same problems (i waited 48 hours before writing this) below i wil post the same information as i did the last time. Any help would be greatly appriecated.
1139000000-1.435256 qam1
3155000000-1.935256 qam3
6179000000-2.436256 qam6
7187000000-2.536256 qam7
10211000000-3.436256 qam10
12227000000-3.435256 qam12
13235000000-3.536256 qam13
17267000000-3.536256 qam17
22307000000-1.737256 qam22
23315000000-1.937256 qam23
1Locked35.721917786
2Locked36.31300318868
3Locked35.5564725636
4Locked36.3585140900
5Locked36.31374716344
6Locked36.3126335715
7Locked36.3103415692
8Locked36.3102463140
9Locked36.3201212458
10Locked36.386751420
11Locked36.38269542318
12Locked35.71085451871
13Locked36.34637354
14Locked36.66381240
15Locked36.33349175
16Locked36.64240174
17Locked36.35441142
18Locked36.62978160
19Locked36.63529794
20Locked36.61553188
21Locked36.61500248
22Locked37.31517239
23Locked37.32349234
24Locked36.62566847
13940000039.5512064 qam4
24620000039.5512064 qam3
35370000039.5512064 qam2
46030000039.8512064 qam1
1ATDMA0060
2ATDMA0040
3ATDMA0040
4ATDMA0060
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057+voc-b.cm
Tags (1)
james315
  • 14
Message 9 of 41
17/01/2021 18:02:56noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2021 13:59:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 17:46:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 17:41:36noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 02:48:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 19:17:26ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 17:41:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 15:15:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 17:56:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 13:53:49noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/01/2021 02:13:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 18:18:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 16:51:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 14:34:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 14:33:42Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 13:37:24noticeSW download Successful - Via Config file
13/01/2021 13:34:50noticeSW Download INIT - Via Config file
01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 11:49:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 10:37:36noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
james315
  • 14
Message 10 of 41
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID 10652
Max Traffic Rate 117000047
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 10651
Max Traffic Rate 10500047
Max Traffic Burst 16320
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
