on 16-07-2023 00:58
Hi guys I’ve had virgin for a few months now and although the speeds are great I find the wifi drops in and out a lot. I’ve recently got an asus wireless router to use for wifi instead. Upon trying to set it up I set the hub 3.0 into modem mode but the router is showing no internet my pc which is wired into the hub 3.0 will connect to the internet fine. When setting up the asus router it says there’s an issue with the dhcp error. And when putting the pc into the asus router it says no valid ip address. I’ve tried checking the hub 3.0 settings but can’t see anything I can change to fix this. Any ideas?
on 16-07-2023 02:13
What router did you get?
You need to set it up in this sequence...
To correctly set it up see Tudor’s message 2 in here….
https://community.virginmedia.com/t5/Networking-and-WiFi/Hub3-in-Modem-mode/td-p/5206738
on 17-07-2023 19:15
Yes because you should unplug the PC from the hub and only have the asus connected you then may need to power off hub for 2mins
on 17-07-2023 20:55
Hi Tomreds, thanks for the message and welcome to the forums.
I am sorry to hear that the WiFi is dropping.
Can you do what Legacy1 has suggested and let us know if things change?
Chris.
