Virgin's Full Fibre Broadband
Good Afternoon,
I have spoken to Virgin and they have told me that the broadband I can receive is full fibre or "fibre optic" as they call it.
According to the sales department, I am able to achieve speeds of up to 350Mbps download but an upload speed of 36Mbps with there M350 package.
If this was full fibre, they should be offering symmetrical speeds. It sounds as if it is FTTC but does anyone know the cabling they use from there in to the premises, CAT 5, CAT 6 for example?
Harry
  • 31.49K
  • 1.65K
  • 5.51K
Re: Virgin's Full Fibre Broadband
its fibre to your house then its converted to coax for the modem and tivo
  • 4.47K
  • 757
  • 1.82K
The vast majority of VM's service if "hybrid fibre-coaxial".  When it works it's very good, but it won't be symmetrical until VM adopt the standard "DOCSIS 4", and that's unlikely until circa 2025.
What you get is a DOCSIS cable connection into your home, and the hub converts that to wifi and ethernet connections.  The "Cat" standard is up to you, bit in reality is only rarely material.
  • 25.12K
  • 1.44K
  • 3.2K
Why “should” it be symmetrical?
