on 17-09-2023 20:00
So I’ve been with Virgin media Broadband for about a week and from day one I’ve been having connection issue, my engineer put a 15db( something to reduce the connection to the box because he said it was coming in too high which could then cause the box to cut out)
My minimum guaranteed speed should be 54mbps but I am getting anywhere between 10-40 on a good day
The first problem we noticed was that we couldn’t watch a simple YouTube video in 1080p 🥴 and then the internet keeps dropping in and out so I did a bit of research and found that separating the frequency and splitting up my devices between 2.4ghz and 5ghz could help with connection issue which I did.
Smart tv
So on the 2.4ghz the picture quality is okay and it can last a bit before dropping out and the 5ghz is definitely the best frequency for performance but it disconnects every 5m 😭
Been on the phone with virgin more times that I can count these past few days and tbh they have been so useless, I don’t want to switch because I know the internet is good it’s just hooked up to a poorly made virgin box, I’ve read that it’s best to put virgin into modem mode and get a another router to broadcast signal which should fix my problem right ? any suggestion on what router to get ?
on 17-09-2023 20:04
What does this site show?
on 20-09-2023 08:18
Hi @satavkupa 👋.
Thanks for reaching out to us. Apologies on the delay with the late reply. Can I ask are you still having this issues or do you require further assistance. I will send you a private message to discuss further should you need to.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
