Virgin media WiFi problems
Having problems with router and WiFi connection. The light just flashes and then stays on for a bit then starts flashing again. I dont know what the problem is or if it’s virgin media that is having the problem.
  • 926
  • 68
  • 127
Well-informed
Re: Virgin media WiFi problems
Can you login to the router via http://192.168.0.1 and check ? It'll say if it has an internet connection or not, and you should be able to access the logs from there too
