on 18-07-2023 05:16
Minimum once a week, virgin will push a new config out and manually change my wireless settings.
I have it set up so 2.4 is channel 11 at 20/40mhz
And 5ghz is 36 at 20/40/80/160mhz
Channel optimization off
And yet I have to manually re set the settings back to how I want because VM comes in and pushes it back to 2.4ghz 20mhz only 5ghz 20/40/80only and channel optimization on. Which makes the internet on one corner of the house unusable. Honestly considering going to my own setup and running it in modem so VM can't fiddle every couple of days.
Running superhub 5
on 18-07-2023 08:08
You are not alone, Hub 3's are also capable of channel wander on 2.4Ghz and changing the bandwidth on 5Ghz.
on 20-07-2023 12:23
Hey Bobstar3233, thank you for reaching out and I am so sorry to hear this.
I have taken a look and everything is look great on our side.
Is there a setting which you've left on by accident which could be swapping the settings?
You can look at some settings here or by loggin into the hub via the settings at the bottom of it. Cheers
Matt - Forum Team
New around here?
on 26-07-2023 11:12
Hello
Gone through it all and no, every so often if I check the logs there's a config download notice but that's it.
Jordan
on 26-07-2023 11:46
I found my hub 3 had a habit of doing this. Strangely the behaviour seemed to be triggered by a momentary interruption of power.
I eventually found after much trial & error, that switching off the power for 10 minutes reset the unit to the values I had originally set, even though they had mysteriously disappeared earlier.
on 26-07-2023 13:41
Hi @Bobstar3233, thank you for your response.
Have you noticed the same thing happening when doing what @nodrogd has described?
Regards,
Daniel
