LindsayS1
  • 5
Virgin WiFi pods
How can you use the ethernet ports on the Virgin WiFi pods
Tags (1)
Andrew-G
  • 6.22K
  • 1.1K
  • 2.64K
Re: Virgin WiFi pods
On any normal mesh wifi setup like my own, you just plug a wired device into the ethernet port, and it should connect.  From the device's point of view that's a wired connection, and the pod and the hub sort out the bit in between.  I'm not familiar with the VM pods, but give that a try, you won't break anything!  Worst that can happen is that the device doesn't connect.
