happytre3frendz
  • 50
Message 41 of 51
Re: Virgin Media's mesh system for M600
Hi Dasco
Can i ask, are you connecting the 2 units using WIFI mesh or Ethernet. ?
Dasco
  • 32
Message 42 of 51
@happytre3frendz wrote:
Hi Dasco
I have mine connected by Ethernet but only because the cable was there. I did use the dedicated 2nd 5Ghz backhaul channel but this can be configured as a third SSID.
So you could have
SSID 2.4Ghz @574Mbps
SSID 5Ghz @1201Mbps
SSID 5Ghz @4804Mbps. Normally used for backhaul.
So it is far faster then Virgins present top speeds so you are future proofing yourself.
happytre3frendz
  • 50
Message 43 of 51
So assuming you use the 5ghz mesh method.
How far do do you think you can be from the node and get signal if the node is getting good signal from the primary router.?
Dasco
  • 32
Message 44 of 51
Each node will cover 255m2 so about 16m. Two nodes cover about 550m2 so for something 25m away you would need a node about half way.
From my post earlier in this thread
 I am getting over 500 Mbps on 5G signal and over 300 on 2.4G signal at furthest point in the house.
Just been down the bottom of the garden and got over 300Mbps on the 5G and over 80Mbps on 2.4G which must be nearly 30 meters from the new router, but I think i'm going to move the node upstairs closer to rear of the house so signal should increase a little more.
I know this kit is expensive but it works and its wifi6 so should be good for few years yet.
  • 26.46K
  • 2.7K
  • 4.9K
Message 45 of 51
Dont forget any wifi or Mesh wifi signal is dependent on the construction of your property and not just its acreage.
If you have walls made of foot thick stone, or iron rich Victorian redbrick, or lined with insulation foil or surrounded by steel RSJ's, etc., then the signal will not get very far.... compared to the paper maché walls of modern properties.
And that's not counting external interference outwith your control.
Dasco
  • 32
Message 46 of 51
My house was built in 1945 signal goes through two walls.
happytre3frendz
  • 50
Message 47 of 51
Ok thanks for the info. Torn between this or the orbi 3 pack mesh system
  • 26.46K
  • 2.7K
  • 4.9K
Message 48 of 51
Mine too, nice soft Cheshire red brick.  However, my mate's 1898 Semi is built of finest quality "hard" Accrington red brick (same a New York Harbour) which is iron rich and hence is a "Faraday cage".  VM installer took over an hour to drill through on install and broke the first drill bit 😂
After the install the Hub wifi signal barely left the room the Hub was in.  I advised him to get a TP-Link Deco M5 mesh system and "strategically place" the other units in "open areas (hall landing, etc) he did that and all connectivity has been fine ever since.
happytre3frendz
  • 50
Message 49 of 51
HI Dasco
Any issues with your set up till to this date? I see many reviews on the system having to reboot itself or something like that. .
For my sister-in law. I plan to set the main hub in the front of the house. The second node will be placed approx 12 metres into the kitchen area using 5ghz backhaul.
The question would be, will the reception go another 20metres where she has her nursery based. So the nursery will be around 20 meters from the node.
Dasco
  • 32
Message 50 of 51
HI Dasco
Its worked perfectly since I fitted it. I can't say for sure that it will work you could try it and if you won't work return it, I got mine through Amazon, you can return stuff on there if it don't perform as expected.
