Nicko-esx
Virgin Media Hub has stopped providing Wifi
Hi my Virgin media hub has stopped emitting any Wi-Fi signal. I have checked the cabling. I have tried and ethernet cable and a signal is being provided by Ethernet but no Wi-Fi. I cannot see the network being broadcast. I suspect the hub has broken. How do I get in contact with somebody at Virgin who can do something about this for me? I have tried to find an appropriate number to call or messaging service and this appears my only option.
  • 35.04K
  • 3.41K
  • 6.66K
Re: Virgin Media Hub has stopped providing Wifi
Try a reset first
_____________
Do a Hub “pinhole reset” - first make sure the 2 passwords on the Hub sticker are still there and legible first ! With the Hub still "switched on" throughout, press the reset pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. Passwords and SSID’s will reset to those on the sticker so log in and change them back to what they were/should be.
See if that sorts it out.
If not - call it in as a fault --- 08.00 is the best time for that
Nicko-esx
Thanks John
I can confirm that I have done exactly as you describe but still nothing
I will try and ring the problem in today if I can find away to contact VM.
Last Night I had little success,
Thanks for the advice
David_Bn
  • 9.36K
  • 388
  • 712
Thanks for your post on our Community Forums @Nicko-esx, and a very warm welcome to you!
Sorry to hear of the issue with the Wi-Fi connection the router.
Check out the purple envelope in the top right hand corner for a private message from me, and I'll have a look into this for you.
Kindest regards,
David_Bn
