Virgin Media 5 Router power lights going off and losing broadband regularly.
Ekflyer
Anyone help with ideas?
My router seems to be losing broadband connection regularly and it looks like its powering down?
Switch it off, wait, on again it connects for a little while then does the same again..
I've previously reset it, works a while then does the same...
Here's what's on my logs:
01-05-2023 22:52:43warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-05-2023 22:52:43noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-05-2023 22:52:39noticeREGISTRATION COMPLETE - Waiting for Operational status
01-05-2023 22:52:33warningDynamic Range Window violation
01-05-2023 22:52:33warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-05-2023 22:52:33warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-05-2023 22:52:33warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-05-2023 22:52:27noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 2 3 4.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-05-2023 22:52:15warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-05-2023 22:52:13noticeHonoring MDD; IP provisioning mode = IPv4
01-05-2023 22:52:03criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-05-2023 22:51:52criticalCable Modem Reboot due to power button reset
01-05-2023 18:08:27criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-05-2023 18:08:15criticalCable Modem Reboot due to power button reset
29-04-2023 19:20:31criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
29-04-2023 19:20:19criticalCable Modem Reboot due to power button reset
25-04-2023 23:04:48criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-04-2023 23:04:37criticalCable Modem Reboot via RG reboot command
25-04-2023 19:11:12criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-04-2023 19:10:33criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-04-2023 19:10:21criticalCable Modem Reboot due to power button reset
25-04-2023 18:59:26criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-04-2023 18:59:15criticalCable Modem Reboot due to power button reset
22-04-2023 08:25:42criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
22-04-2023 08:25:30criticalCable Modem tr069-reboot
16-04-2023 10:33:18criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
16-04-2023 10:33:06criticalCable Modem tr069-reboot
1 REPLY 1
Nathan_B
Hi there @Ekflyer 👋 Welcome to our forum and thanks for your post 😊
Sorry to see you've been having issues with your connection dropping, I can understand this is frustrating 😔
I have taken a look at our system for you and can see that there are some issues with the connection showing from here. I'll send you a PM to confirm your details so this can be discussed further.
Nathan
