Virgin Hub 5 - WiFirandomly stops
krisnewton
Not sure if others are experiencing the same issue, but randomly my internet stops working.  My devices stay connected via WiFi but there’s just not internet connectivity.  I don’t have anything running via LAN so can’t comment if that’s the same.  If I connect onto the hub it shows the green ticks as if everything is fine.  The only way I can get it to work again is by switching the hub off and on again which isn’t great when you have to do this daily.
2 REPLIES 2
Legend
Hub 5 Wi-Fi & DHCP can be unreliable and / or fail if the SSIDs have been changed.
Alex_RM
Hi krisnewton,
Thanks for posting and welcome to our community 🙂
Sorry to see you've been having some connection issues. I've had a look at things from our side, and there are no area issues affecting you. So I can go a few more diagnostics with you, I've popped you over a private message.
Alex_Rm
