MXmaster
Virgin Hub 3 - Can I create MESH network?
First post so here goes...
Current WIFI in house is OOmp bundle.
But suffer massively with dead spots around house to the point I bough 3 TPLink extenders but they all have their own name for connection (IE: Bedroom, Back Room, Kitchen)
I have heard of MESH systems, which means as we move between rooms, we don't need to keep switching manually to the extenders (Which is a pain!) by room type, but the extenders have MESH capability, but the set-up states the Virgin hub 3 doesn't support MESH.
Anyone know of a way to boost WIFI in these deadspots some other way without need for all the different networks to join manually?
Some say turn the Virgin 3 hub into a MODEM mode then buy a supported MESH router? Anyone done this and recommend any from Amazon?
gary_dexter
  • 30.61K
  • 1.9K
  • 4.07K
Re: Virgin Hub 3 - Can I create MESH network?
Why extenders did you get?
You’ll need a compatible TP-Link router to utilise the mesh system the extenders offer.
Treble1
  • 214
  • 43
Superfast
Just put the sh3 in modem mode and get the asus xt8 pair £399 currys amazon are oos job done
