Hello Tudor
The issues are not consistent
I can get the hub to work ok (not great) when in Router mode
If I connect the Asus to the Hub in router mode it also works ok (not great)
When I put the Hub in modem mode, the asus works ok for a while and then the wifi drops out and then re-establishes before working ok for a bit and then dropping out etc
All the while the down load is between 50 and 100 but the upload varies from 0.1 to about 9
I am convinced there is something wrong with the hub, from all the tests and various combinations I have tried out
Currently on second call to VM - just want someone to come out and test the Hub or replace it, as I am convinced that is where the problem lies
