Virgin HUB 4 SETTINGS UPGRADE: Zero of my devices will now connect.
K87
You emailed me a couple of weeks ago with a link to nothing. Ive only just read the email about opting out to you changing my Hubs settings. So I Didnt get a chance to opt out as im too late. Youve messed with my network settings and now none of my devices (amazon echo/firesticks/ light bulbs / smart plugs/ ) will work. How can i get it back to the original configuration i had to set to before you guys meddled without my permission?
Or how can i get all of my devices to work with what ever youve done to my HUB?
K
2 REPLIES 2
VM network your own network would be your own router with hub in modem mode
so what shall i change the settings of the router? i havent dabbled that deep into yet to look at what you can do, can do that later when i get home?
K
